Replace a char in a String
I feel this is to simple but i can`t remove a char of a String.
i tried to use “replace” , but Ignition sends me an error “replace is not defined”,
i put this in an event and a script and is the same error.
this is my code: replace(MyString, anychar , “”)
i forgot something?
thanks
Where are you trying to do this?
Are you trying to write Jython code or an expression?
MyString.replace(anychar,'')
myString = 'TestxString'
print myString.replace('x', ' ')
Test String
tried to inside of an event in a button.
after tried in a script and i call the script inside the event of the button
As @dkhayes117 example shows, replace is a method on the string, not a standalone command.
Don’t forget you can use the script console under tools. I sometimes find it easier to play around in the console rather than in a window or in a component.
https://docs.inductiveautomation.com/display/DOC80/Script+Console
thanks, i solved my problem.
Thanks kevin.Herron and witman
