Search result ‘[default]types/Old/E_Nickel/UDT_MS/FLT/NON_CRIT_STATUS.opcItemPath’ is not a String
Good day,
I am receiving this error after I try to replace the OPC Path Device Name on my UDT tags.
We changed our device name after we started a project which in turn made all of our tags in the designer no longer work because of the path change. Essentially I thought I could just find replace in the OPC path name but it is not looking like I can do this.
Aside from recreating all of my UDTs, is there an easier way to “replace” the OPC path name? For Example:
Instead of : ns=1;s=[Old]Program:{StationName}.RECIRC_PUMP.CATALOG_NUM
I want: ns=1;s=[New]Program:{StationName}.RECIRC_PUMP.CATALOG_NUM
Thanks!
