I create a report chart with pens below :
I have list of dictionnaries like [{'key':'value1','title':'my pen title'} , ...]
How can I dynamically put my pens' titles in the chart legend by script ?
You'll need to adjust your pen names via the configureChart hook. I'd recommend searching the forum for example code to start from.
My chart is in a table row which depends on values in a dataset like below :
How can I get my legend variable in chart script ?
from org.jfree.chart import JFreeChart
from org.jfree.chart.plot import XYPlot
from org.jfree.data.xy import XYSeriesCollection, XYSeries
plot = chart.getXYPlot()
dataset = plot.getDataset()
# Create a new dataset with updated series keys
newKeysDict = [{'value1':'my pen title'} , ...]
if dataset is not None and dataset.getSeriesCount() > 0:
newDataset = XYSeriesCollection()
for i in range(dataset.getSeriesCount()):
seriesKey = dataset.getSeriesKey(i)
newLabel = newKeysDict[seriesKey] # Update the label
# Create a new series (you'll need to copy data points)
newSeries = XYSeries(newLabel)
for j in range(dataset.getItemCount(i)):
x = dataset.getXValue(i, j)
y = dataset.getYValue(i, j)
newSeries.add(x, y) # Add data points
newDataset.addSeries(newSeries)
# Set the new dataset to the plot
plot.setDataset(newDataset)
in case anyone is looking for something similar.
