Ignition 7.8.0 b2015101414
Gateway Java 1.8.0_65 on Win Server 2012R2
Designer Java 1.8.0_66 on Windows 7
In the Report Designer, on a table header, I have a static Text object. When I select it and press Ctrl-C, Ctrl-V, instead of another text object with the same contents and formatting, I get a default text box with what looks like the XML for the object as its text.
<?xml version="1.0" encoding="UTF-8"?>
<alist>
<text x="5" y="6" width="110" height="72" valign="middle">
<font name="Consolas Bold" size="10" />
<color value="#ffffff" />
<string>Covers @StartDate@ to @EndDate@</string>
<format type="date" pattern="yyyy-MM-dd HH:mm:ss" null-string="<N/A>" />
<format type="number" pattern="#0.##" null-string="<N/A>" />
</text>
</alist>
Ctrl-Drag doesn’t work, and there is no right click menu, so I can’t try any other methods for copy/pasting (the ctrl-drag for duplicate would be good to have here as well).
Just another minor gripe, I appreciate the work you guys do so I want to help improve if I can.
