My report has a query data source of the form,
SELECT TOP 1 VALUE
FROM my_table
WHERE orderNum = ?
On the report Design tab it shows up in the Data Sources:
I want to script a derived value. How do I access InnerLabel.VALUE from my script? I've tried variations of
innerLabel = data['InnerLabel'].getCoreResults().getValueAt(0, 'VALUE')
data['InnerLabelGTZero'] = innerLabel
but InnerLabelGTZero doesn't appear in the Data Sources list. I suspect that I'm not accessing VALUE correctly. (type(data['InnerLabel']) seems to be a 'class'.)
Any ideas? Thanks!
Huh. Did you configure InnerLabel as a scalar query?
Hi, Phil.
No, I'm using a Report Data SQL query and that's not an option - is it?
Hmm. Conflated with UI bindings. Sorry.
I think what I'm seeing is no row returned at all.
I just threw this together and it worked right off the bat
data['tbegin'] = data['query2'].getCoreResults().getValueAt(0,'TimeBegin')
Where query2 is a simple
select top 1 ['TimeBegin'],['TimeEnd'] from table
I am with Phil in I think your select isn't returning a row?
I suspect you're both right. I'm finding debugging in Reports a bit tedious!
A common pitfall is to override the builtin data variable inside a report script. Similar to using system for a variable name in a script.
Probably not your issue, but good to be aware of.
