Report Data Sources - data key alias removing characters and adding underscores
This one "pdu_current_a" and many others are ok but the last two change.
The data key alias '1a_2_pdu_current_a1' becomes 'a_2_pdu_current_a1__' in the design page Key Browser.
Pretty sure you can't have keys that start with a digit.
That seems to be the issue. Odd way to deal with it.
Nah. There's so many ways way identifier problems can manifest that this one seems pretty benign. It's a long-standing rule of mine that anything that is a name anywhere in Ignition gets something that can serve in python as a valid variable name.
Once you see it I guess but I don't know much about python and my memory is bad now. They could warn you if you try and start it with a number. I've learned to avoid spaces, special characters and dashes but I'm not used to having to worry about case and now leading numbers.
FWIW, we do have a couple of tickets to deal with this issue. I'll attach this forum thread to get them bumped up in priority a bit.
