HALW80
January 3, 2017, 11:02am
1
We have a report which uses the dateArithmetic function:
dateFormat(dateArithmetic({Root Container.Popup Calendar.date}, -1, “days”), “dd-MM-YYYY”)
dateFormat(dateArithmetic({Root Container.Popup Calendar.date}, -2, “days”), “dd-MM-YYYY”)
dateFormat(dateArithmetic({Root Container.Popup Calendar.date}, -3, “days”), “dd-MM-YYYY”)
etc
When a client is open the value for the 1/1/2017 from data base is correct but the header shows the 1/1/2016
In designer when I run the test button and change the calendar it shows the 1/1/2017 as expected.
Can you give us a little more info? It would help to know what version of Ignition you’re running, and what version of java the Designer and Client are running. Are the Designer and Client on the same machine?
HALW80
January 3, 2017, 4:19pm
3
Java 8 v73
Ignition 7.8.2
Yes Designer and Client on the one machine
HALW80
January 3, 2017, 4:23pm
4
Its fine when I don’t include 1/1/2017
Can you contact support on this? I’m not able to replicate the issue with Ignition 7.8.5 and Java 8u91.
Just in case anyone is looking for the answer, I just figured it out on my 7.9.9 server.
Change the YYYY to yyyy
