In designing a report, I would like to make an object invisible when a key string is null.
According to the Dynamic Example section here:
inductiveautomation.com/prod … sermanual/
the isVisible property should be able to do that with an expression like
thisstring <> “”
or
thisstring <> ‘’
or
@thisstring@ <> “”
etc, but none of these seem to work.
d1234,
Help me better understand what you’re trying to do.
Do you simply want nothing displayed in a cell of a table?
Or is there some report element, such as a table or graph, that you want to make visible or invisible based on the NULL value?
There is report element, such as a table or graph, that I would like to visible or invisible based on whether a string is NULL or not. If the string is NULL, I would like the element to be invisible. If the string is not NULL, then display the object.
Sorry, figured it out. The format is
thisstring != “”
Thank you for your consideration.
edit - you did it. Here’s a way if the condition is outside the report.
- In the report customizer, near the bottom of the screen, click the blue database looking icon to modify Dynamic Properties for the report.
- Create a boolean dynamic property called visibility (for example)
- Select the component you want to be (conditionally) invisible
- On the right, click the icon that looks like a checklist (between the rulers and clock)
- Under Property Expressions, highlight isVisible.
- In the text box below, type the name of your property (visibility), then hit enter.
- You should see that name in the table. (You don’t need the “@” substitution signs - it does it for you on that table).
- Click OK to close the report customizer.
- In the FPMI designer, select your report. You will see the your new dynamic property visibility. You can now bind this to whatever expression you’d like.
