I am looking to perform a subtract function on a column of a dataset (with 2 rows) from within the report plugin. I want to do just the opposite of what the TOTAL key does. Is there an easy way to do this?
Sure, just put a keychain expression like this in a text box in your report:
@Data[0].Value - Data[1].Value@
i have a data set with multiple rows, and multiple columns. lets say, ID from 1 to 10.
How do i subtract column1 with id1 from column1 with id2 and so on, and do that with all the columns?
I don’t think it’s possible to reference previous rows in the Reporting Plugin. I entered a feature request for a keyword like Last or Previous. In your case it would be @Col1-Last.Col1@.
There is probably a way to get the difference of a columns value between rows. I can’t think of how. This article might point you in the right direction.
Usually this is done in a SQL query that joins the table together, like:
SELECT A.Col1-B.Col1 FROM MyTable A JOIN MyTable B ON A.Id=B.Id-1
