My Question is : Inside Report Designer I Create a table. Usually the Object details is displayed in rows. Is there any way that can display Object details in columns…
Currently there is no way to show your object details in columns unless you use the simple table, but that could be a ton of work since the idea of a table is that is has an indeterminate number of rows. If your data is of a variable length, you could try using your database’s PIVOT function to show the rows as columns in your raw dataset and use that in the report.
