Report execute and distribute parameters
I have a report with multiple parameters. Some of the parameters are dependent on previously defined parameters.
For instance: Duration = minutesBetween({StartDate},{EndDate})
This works fine when running the report on a schedule. However, when running the report using system.report.executeAndDistribute() and passing the StartDate and EndDate parameters in, the calculated parameter “Duration” is not calculated.
Hmm… that’s certainly not what I expect.
What version are you running?
I am running 7.9.7 (need more characters before I can reply…)
Sorry it took me a couple of days to get back to this. I can’t replicate this in 7.9.9, and nothing in this code has changed since 7.9.7. You’ll need to double check your script, and perhaps contact support for help on this.
Did you ever solve this problem? I’m having the same exact problem on 8.0
I worked around it by querying my data for the StartDate and EndDate and then calculated the duration using:
system.date.minutesBetween(StartDate,EndDate)
