Entering ‘design mode’ of an ignition report i have a several minute ‘loading’ delay, then the following error is raised (full details also below),
ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
caused by GatewayException: Read timed out
caused by SocketTimeoutException: Read timed out
Ignition v8.0.15 (b2020072213)
Java: Azul Systems, Inc. 11.0.6
After 'ok’ing that, the design screens appear ok, except the key browser only shows ‘builtins’, and nothing at all from the report data (calculation queries, etc)
Entering report ‘preview’ i get a white screen with
‘java.util.concurrent.ExecutionException: java.lang.IndexOutOfBoundsException: Index 0 out of bounds for length 0’ … and no report preview
This has suddenly happened for all the reports i have setup, not just the one i have been working on today. HOWEVER when create a new ‘test’ report, the key browser is fully populated, and there are no similar problems entering preview or design mode - everything with that works ok.
What has happened? and How do i fix it ?
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
at java.desktop/javax.swing.SwingWorker.get(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.done(SampleData.java:145)
at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:96)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:530)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:897)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:53)
at com.sun.proxy.$Proxy54.getReportData(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:135)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:112)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(Unknown Source)
at java.base/java.net.SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.fill(Unknown Source)
at java.base/java.io.BufferedInputStream.read1(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:437)
... 13 more
