Report issue in Ignition
Hello,
I am trying to convert decimal numbers to whole numbers in a respective column in a Report.
Right now the column is showing whole numbers but in the xml format it is showing in decimal format.
I tried changing the number format in the properties section but it did not work.
Can you please help me out with this issue!?
Can you share some screenshots of the behavior and the settings you've tried?
This example was not the report module, but if I'm understanding you correctly, the problem seems similar. Perhaps it will help you:
