I save the file as pdf in the rep
ort schedule, but the file is garbled and the language is ChineseBeOnDutyTable2020101009.pdf (40.2 KB)
this need help
hi
Since reports are generated on the gateway, I suspect the problem is a missing font on the gateway. Or a font on the gateway that Ignition hasn’t been configured to use. (I’m not very good with font setup.)
i see
Do you see anything in the server logs? Go to your gateway Status->Logs, try making a report, and see if anything regarding reports pops up. You may need to change logging levels for the reporting module though if this is not something the Module considers a error, and given you are at least able to produce a .pdf, it seems like might be necessary.
Phil is right here.
When you see empty boxes where characters should be, it’s because the font can’t display that character. If you’re using a current version of Ignition, we don’t include the CJK fonts by default because they are so large – see this post for how to install them.
