Hi, I have the same issue as
I have multiple history tags linked to it and would like to have the individual tags on x axis.
At the moment it just shows the average of the whole thing.
How would I do that?
I’m not quite clear on what you want to do, but between being able to have multiple tag history data sources and the scripting data source, which lets you combine and modify results from the data sources above it, you should be able to do whatever you want.
Thanks, Yes I probably need to script the data source. Cheers
