Report module, executeReport error
Hello,
First time dealing with report module (working on version 8.1.43),
if i generate a report via system.report.executeReport(path=path, project=project, parameters={}, fileType="pdf")
two things happen:
  1. If I create a Test Report, containing only shapes, like a rectangle and a start, it work and then i can create a file and download the report as pdf
  2. If I insert any other component, like text for example, even if I write static text without binding to parameters, ( I deleted all parameters from the report), I receive this error. I want to point out that i tried multiple components, bindings, and all of those are working correctly while developing the report and viewing it in preview page. I only get this error when i call the executeReport.
00:45:48.991 [AWT-EventQueue-0] ERROR com.inductiveautomation.ignition.client.util.gui.ErrorUtil -- <HTML>Error executing script for event:&nbsp;<code><b>actionPerformed</b></code><BR>on component:&nbsp;<code><b>GeneraReport</b></code>.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last):
  File "<event:actionPerformed>", line 9, in <module>
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:930)
	at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:53)
	at jdk.proxy2/jdk.proxy2.$Proxy61.executeReport(Unknown Source)
	at com.inductiveautomation.reporting.scripting.ClientScriptingFunctions.executeReport(ClientScriptingFunctions.java:35)
	at com.inductiveautomation.reporting.common.scripting.ReportScriptingFunctionsPyWrapper.executeReport(ReportScriptingFunctionsPyWrapper.java:62)
	at jdk.internal.reflect.GeneratedMethodAccessor1779.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.reflect.InvocationTargetException
	at org.python.core.Py.JavaError(Py.java:545)
	at org.python.core.Py.JavaError(Py.java:536)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
	at org.python.core.PyObject.__call__(PyObject.java:400)
	at org.python.pycode._pyx1674.f$0(<event:actionPerformed>:11)
	at org.python.pycode._pyx1674.call_function(<event:actionPerformed>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1703)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:804)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:207)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:300)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at jdk.proxy2/jdk.proxy2.$Proxy64.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.base/java.security.AccessController.doPrivileged(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
	at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:99)
Caused by: org.python.core.PyException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.reflect.InvocationTargetException
	... 51 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.reflect.InvocationTargetException
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	... 48 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: java.lang.reflect.InvocationTargetException
	at sun.font.FontManagerFactory$1.run(null)
	at java.security.AccessController.doPrivileged(null)
	at sun.font.FontManagerFactory.getInstance(null)
	at sun.font.SunFontManager.getInstance(null)
	at sun.font.FontDesignMetrics.getMetrics(null)
	at sun.java2d.SunGraphics2D.getFontMetrics(null)
	at com.inductiveautomation.rm.text.RMFontFile.getMaxAscent(RMFontFile.java:228)
	at com.inductiveautomation.rm.text.RMFontFile.getLineHeight(RMFontFile.java:259)
	at com.inductiveautomation.rm.text.RMFont.getLineHeight(RMFont.java:239)
	at com.inductiveautomation.rm.text.RMTextLayout.addLine(RMTextLayout.java:419)
	at com.inductiveautomation.rm.text.RMTextLayout.layoutText(RMTextLayout.java:166)
	at com.inductiveautomation.rm.text.RMTextLayout.layout(RMTextLayout.java:120)
	at com.inductiveautomation.rm.shape.RMTextShape.getTextLayout(RMTextShape.java:803)
	at com.inductiveautomation.rm.pdf.writer.RMTextShapePdfr.writeShape(RMTextShapePdfr.java:31)
	at com.inductiveautomation.rm.pdf.writer.RMTextShapePdfr.writeShape(RMTextShapePdfr.java:20)
	at com.inductiveautomation.rm.pdf.writer.RMShapePdfr.writeShapeAll(RMShapePdfr.java:56)
	at com.inductiveautomation.rm.pdf.writer.RMShapePdfr.writePDF(RMShapePdfr.java:26)
	at com.inductiveautomation.rm.pdf.writer.RMShapePdfr.writeShapeChildren(RMShapePdfr.java:98)
	at com.inductiveautomation.rm.pdf.writer.RMShapePdfr.writeShapeAll(RMShapePdfr.java:59)
	at com.inductiveautomation.rm.pdf.writer.RMShapePdfr.writePDF(RMShapePdfr.java:12)
	at com.inductiveautomation.rm.pdf.writer.RMPDFWriter.writeDocument(RMPDFWriter.java:347)
	at com.inductiveautomation.rm.pdf.writer.RMPDFWriter.getBytes(RMPDFWriter.java:87)
	at com.inductiveautomation.rm.shape.RMDocument.getBytesPDF(RMDocument.java:748)
	at com.inductiveautomation.reporting.gateway.actions.ReportActionUtils.getBytes(ReportActionUtils.java:33)
	at com.inductiveautomation.reporting.gateway.scripting.GatewayScriptingFunctions.lambda$executeReport$0(GatewayScriptingFunctions.java:134)
	at com.inductiveautomation.reporting.gateway.ReportingGatewayHook.executeReport(ReportingGatewayHook.java:328)
	at com.inductiveautomation.reporting.gateway.ReportingGatewayHook.executeReport(ReportingGatewayHook.java:247)
	at com.inductiveautomation.reporting.gateway.scripting.GatewayScriptingFunctions.executeReport(GatewayScriptingFunctions.java:133)
	at com.inductiveautomation.reporting.gateway.ReportingGatewayHook$RPC.executeReport(ReportingGatewayHook.java:646)
	at jdk.internal.reflect.GeneratedMethodAccessor290.invoke(null)
	at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
	at java.lang.reflect.Method.invoke(null)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:167)
	at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:435)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
	at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
	at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:598)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1580)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1553)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
	at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
	at org.eclipse.jetty.server.Server.handle(Server.java:563)
	at org.eclipse.jetty.server.HttpChannel$RequestDispatchable.dispatch(HttpChannel.java:1598)
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:753)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:501)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:287)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
	at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:421)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:390)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:277)
	at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:199)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
	at java.lang.Thread.run(null)
Thank you
Sorry, running on debian.
Fixed by
Install fontconfig from apt.
edit: ah, that's the solution linked the post too.
