Report Module - Gateway Exception
Upgraded to 8.0.3 today. Running on Linux (Ubuntu 16.04).
I was able to send reports via email but now I’m getting this Gateway exception:
Could not initialize class com.inductiveautomation.rm.graphics.RMImageData
and sometimes this:
Could not initialize class java.awt.GraphicsEnvironment$LocalGE
Any ideas on what’s going on?
I think it’s good now… I simple restart on the gateway again seemed to fix this:
/usr/local/bin/ignition/ignition.sh stop
/usr/local/bin/ignition/ignition.sh start
If you see this again click the “full” button on that error dialog, copy the full stack trace, and let us know.
ok sounds good, will do!
This same thing happened to me, Here is the Full error dialog:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Could not initialize class java.awt.GraphicsEnvironment$LocalGE
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:315)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:880)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:53)
at com.sun.proxy.$Proxy50.execute(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.schedule.SchedulePanel$ActionsPanel$ExecuteNowWorker.doInBackground(SchedulePanel.java:668)
at com.inductiveautomation.reporting.designer.workspace.schedule.SchedulePanel$ActionsPanel$ExecuteNowWorker.doInBackground(SchedulePanel.java:641)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class java.awt.GraphicsEnvironment$LocalGE
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(null)
at java.awt.image.BufferedImage.createGraphics(null)
at com.inductiveautomation.rm.shape.j2dshapes.AbstractJ2DShape.getDisplayedFill(AbstractJ2DShape.java:73)
at com.inductiveautomation.rm.out.RMExcelWriter.append(RMExcelWriter.java:304)
at com.inductiveautomation.rm.out.RMExcelWriter.getWorkbook(RMExcelWriter.java:162)
at com.inductiveautomation.rm.out.RMExcelWriter.getBytes(RMExcelWriter.java:96)
at com.inductiveautomation.rm.shape.RMDocument.getBytesExcel(RMDocument.java:738)
at com.inductiveautomation.rm.shape.RMDocument.writeExcel(RMDocument.java:885)
at com.inductiveautomation.reporting.gateway.actions.SaveFileReportAction.saveReport(SaveFileReportAction.java:163)
at com.inductiveautomation.reporting.gateway.actions.SaveFileReportAction.perform(SaveFileReportAction.java:105)
at com.inductiveautomation.reporting.gateway.scheduler.ReportSchedulerTask.reportAction(ReportSchedulerTask.java:322)
at com.inductiveautomation.reporting.gateway.scheduler.ReportSchedulerTask.runImmediate(ReportSchedulerTask.java:294)
at com.inductiveautomation.reporting.gateway.scheduler.ReportSchedulerTask.runImmediate(ReportSchedulerTask.java:262)
at com.inductiveautomation.reporting.gateway.ReportingGatewayHook$RPC.execute(ReportingGatewayHook.java:435)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(null)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:165)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:409)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:530)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
at java.lang.Thread.run(null)
Ignition v8.0.3 (b2019080717)
Java: Azul Systems, Inc. 11.0.3
What OS are you on? If it’s Linux, do you have X11 or any kind of graphics environment installed?
Thanks for the reply. I am using Ubuntu Server 18.04. Doesn’t have X11 that I am aware. I think a QT package was installed for Oracle VMWare though.
Wait, seems that X11 is there, is there some configuration required?
No, just guessing at things right now. If you have a graphical environment you probably have X11.
I have the same issue on red hat Server 7.7 here is the full error log:
File “event:keyReleased”, line 26, in
at com.sun.proxy.$Proxy58.executeAndDistribute(Unknown Source)
at com.inductiveautomation.reporting.scripting.ClientScriptingFunctions.executeAndDistribute(ClientScriptingFunctions.java:44)
at com.inductiveautomation.reporting.common.scripting.ReportScriptingFunctionsPyWrapper.executeAndDistribute(ReportScriptingFunctionsPyWrapper.java:77)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Could not initialize class com.inductiveautomation.rm.graphics.RMImageData
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.Py.JavaError(Py.java:543)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:519)
at org.python.core.PyObject.__call__(PyObject.java:413)
at org.python.pycode._pyx6.f$0(<event:keyReleased>:29)
at org.python.pycode._pyx6.call_function(<event:keyReleased>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:770)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:200)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:291)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at com.sun.proxy.$Proxy59.keyReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.keyReleased(Unknown Source)
at java.desktop/java.awt.Component.processKeyEvent(Unknown Source)
at java.desktop/javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.desktop/java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Could not initialize class com.inductiveautomation.rm.graphics.RMImageData
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:188)
… 46 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class com.inductiveautomation.rm.graphics.RMImageData
at com.inductiveautomation.rm.shape.RMImageShape.fromXML(RMImageShape.java:419)
at com.inductiveautomation.rm.archiver.RXArchiver.fromXML(RXArchiver.java:240)
at com.inductiveautomation.rm.archiver.RXArchiver.fromXML(RXArchiver.java:224)
at com.inductiveautomation.rm.archiver.RXArchiver.fromXML(RXArchiver.java:185)
at com.inductiveautomation.rm.shape.RMParentShape.fromXMLChildren(RMParentShape.java:710)
at com.inductiveautomation.rm.shape.RMPage.fromXMLChildren(RMPage.java:764)
at com.inductiveautomation.rm.shape.RMParentShape.fromXML(RMParentShape.java:688)
at com.inductiveautomation.rm.shape.RMParentShape.fromXML(RMParentShape.java:19)
at com.inductiveautomation.rm.archiver.RXArchiver.readObject(RXArchiver.java:148)
at com.inductiveautomation.rm.archiver.RXArchiver.readObject(RXArchiver.java:133)
at com.inductiveautomation.reporting.common.resource.PageTemplate.getTemplate(PageTemplate.java:42)
at com.inductiveautomation.reporting.gateway.scripting.GatewayScriptingFunctions.executeAndDistribute(GatewayScriptingFunctions.java:320)
at com.inductiveautomation.reporting.gateway.ReportingGatewayHook$RPC.executeAndDistribute(ReportingGatewayHook.java:469)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:411)
at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
Ignition v8.0.8 (b2020021111)
Java: Azul Systems, Inc. 11.0.5
