I’m trying to create a Gantt chart in the reporting module. My first attempt was to use the chart scripting to take advantage of the jfree chart and change the bar chart into a gantt chart. I do not get any errors with my script, but it still renders the bar chart in the report. Has anyone been successful in building a Gantt chart in the reporting module?
def configureChart(data, chart):
Provides an opportunity to perform chart
configuration right before the report is
rendered. Report Parameters and Data Sources
are accessible via the data['myKey'] command.
Arguments:
data: This is a map whose keys are report
data keys. Values should be sequences,
maps, scalar values, or Datasets.
chart: A JFreeChart object that will be
drawn on the report.
from org.jfree.chart import ChartFactory
from org.jfree.data.category import IntervalCategoryDataset
from org.jfree.data.gantt import Task
from org.jfree.data.gantt import TaskSeries
from org.jfree.data.gantt import TaskSeriesCollection
s1 = TaskSeries("Series 1")
s1.add(Task("Test1", system.date.addDays(system.date.now(),-8), system.date.addDays(system.date.now(),-6)))
s1.add(Task("Test2", system.date.addDays(system.date.now(),-6), system.date.addDays(system.date.now(),-4)))
s1.add(Task("Test3", system.date.addDays(system.date.now(),-4), system.date.now()))
dataset = TaskSeriesCollection()
dataset.add(s1)
chart = ChartFactory.createGanttChart('Gantt Chart', 'TaskName', 'Date', dataset, True, False, False)
