Report module - Use scripts to configure objects
Hello! I am new here
Talking about reporting module, my question is: is it possible to write scripts into report objects in order to modify a report template layout on the basis of a particular event?
For example: I have a template and I want to show / hide a table or a graph depending on a particular event.
Yes, you can right click and set a property to dynamic in the report designer.
Thank you! I check in report designer ( opening demo project) and i see that it is possible to create dynamic reports changing data into tables and graphs. However, i can’t right click on components into report designer. Where is the property that you mentioned before?
Add your component to the report, then left click on the Visibility property to select it, then right click and select “Use dynamic data key”
Thanks a lot! I ve found it!
