I have report triggered by PLC tag indicating that the process is over. Usually there might 7-8 triggers per shift. The report is executed and saved in the directory for that purpose, but every new generated report overwrites the previous one, since they have the same name. I was wondering what workaround to find, any ideas?
Put the timestamp with minutes and seconds into the filename?
If the report name is, for example, MachineNo1, how the new name with the timestamp will look like?
You can format it as you choose;
e.g. MachineNo1_20210623_17_01_03.PDF
I meant how to include the timestamp like variable in my script?
Use a fileName parameter in the settings
# Executes and distributes the report to save a PDF
now = system.date.now()
date = system.date.format(now , "yyyy-MM-dd HH:mm:ss")
fileName = "MachineNo1 _%s" % date
settings = {"path":"C:\\Ignition Reports", "fileName":fileName, "format":"pdf"}
system.report.executeAndDistribute(path="My Report Path", project="My Project", action="save", actionSettings=settings)
Use system.date.now and format it before adding to the filename
from the manual
settings = {"path":"C:\\Ignition Reports", "fileName":"Report.pdf", "format":"pdf"}
@Matrix_Engineering LOL, beat you by mere seconds
Thanks a lot, guys!
There is a small Python syntax issue in your script, dkhayes117, and I could not find solution.
system.report.executeAndDistribute accepts only arguments in quotes (" ") after “fileName”:, but then logically the report name stops to be variable.
you sure you did this?
Yes it works for me, just ran it and it produced
>>>MachineNo1_2021-06-24 08:14:32
EDIT: Make sure you use the correct variable in your settings
{ ... "fileName":fileName, ... }
Ah hm try system.date.format(now , "yyyy-MM-dd-HH-mm-ss")
And be sure there is no space before the date.
Might be that filenames cant have “:” in it
You defintly should not put quotes around fileName, cuz its a variablename not a string
That was it! “:” replaced with " - ", and issue solved.
Thank you!
hehe forgot about that xd
