Report Preview Error
Working on my reporting today and out of the blue I am getting "Error getting sample data," when trying to preview the report. Worked fine all last week and no changes were made between friday and today. The only change that was made was a scheduled email of the report.....I did see some users were having issues with this error when the report was scheduled, but I thought it was fixed with ignition 8.0. Ill add the details of the error to see if anyone has any ideas. I should note, the report sent in the email populates properly and looks exactly like it should.
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
at java.desktop/javax.swing.SwingWorker.get(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.done(SampleData.java:145)
at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:99)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:543)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:283)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:908)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:53)
at com.sun.proxy.$Proxy59.getReportData(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:135)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:112)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(Unknown Source)
at java.base/java.net.SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.fill(Unknown Source)
at java.base/java.io.BufferedInputStream.read1(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:437)
... 13 more
Ignition v8.1.18 (b2022061518)
Java: Azul Systems, Inc. 11.0.15
I have also looked at gateway performance when running the report and it sits around 50% usage on the ram side and the cpu usage doesnt get very high at all.
"Read timed out". That means the report is taking more than 60 seconds to generate. That is a hard-coded limit for all requests from Vision clients to the gateway. Examine your database for poor optimization on the elements of this report.
Not sure exactly what to look for and how to optimize it any more efficiently. The report preview loads about 50% of the time, so it varies how long it is taking. I have about 50 or so tags being read in to the script.
Presumably there's some history queries involved? Start with those (in your DB, not in Ignition).
I have the same issue recently but on Ignition version 7.9.20, did you find the root cause?
