Hello, I am trying to make a summary table print on just the top of the first page of a report. Normally, I’d just put this in the first only header of the table. In this case I have the table repeating three times horizontally so the header is only 1/3 of the page. I’d like this summary table to span the whole page width. I think I must be over complicating this but if I put any table or text in it repeats on every page. Is there an indicator to print just on first page? See attached images of table repeating/format in designer. Thanks!
Sounds like you want peer tables. Peer tables are designed to print one after the other, so your header table would print just once and then your second table would follow, taking as many pages as it needs.
