Hello, I have a question regarding Reports going out at Schedule time. I have a single Report with multiple schedules at the same time, but are fed different parameters. I am seeing intermittent delivery of them.
For example, 11pm one day, I see schedule event 1 but not 2, then at 7am I see schedule event 2, but not 1, and then another day I could see both.
I am trying to determine if the SMTP server is failing and to use resources looking there, or if this is an Ignition Limitation/Failure. I can't find anything in the logs about a failed report.
Any advice where to look, or if this definitely seems like an SMTP issue? I could offset each report by a minute as well but seems like a bandaid.
