Report script error
	from system.dataset import toDataSet
	from datetime import datetime
	query = (
		"SELECT "
		    "P.PowerDistributeIndex, "
		    "P.PowerDistributeName, "
		    "P.GroupNo, "
		    "P.FeederCount, "
		    "G.GrpName "
		"FROM "
		    "tblPowerDistInfo AS P "
		"JOIN "
		    "tblMCGrpName AS G ON P.GroupNo = G.GrpNo "
		"ORDER BY P.GroupNo,P.PowerDistributeName ASC "
	data = system.db.runQuery(query)
	pd_data = {}
	for row in data:
		pd_index = row["PowerDistributeIndex"]
		pd_name = row["PowerDistributeName"]
		group_no = row["GroupNo"]
		grp_name = row["GrpName"]
		if len(grp_name.split(" ")) < 2:
			floor = ""
			location = grp_name
		else:
			floor, location = grp_name.split(" ")
		pd_data[pd_index] = {
			"pd_name": pd_name,
			"group_no" : group_no,
			"floor" : floor,
			"location" : location,
			"use_rate" : "",
			"vol_r" : 0.0,
			"vol_s" : 0.0,
			"vol_t" : 0.0,
			"cur_r" : 0.0,
			"cur_s" : 0.0,
			"cur_t" : 0.0,
			"power_r" : 0.0,
			"power_s" : 0.0,
			"power_t" : 0.0,
			"power_sum" : 0.0,
			"powerkWh" : 0.0
	# load tag data
	start_date = data["StartDate"]
	end_date = data["EndDate"]
	#start_date = system.date.parse('2023-12-01 00:00:00', 'yyyy-MM-dd hh:mm:ss')
	#end_date = system.date.parse('2023-12-05 23:59:59', 'yyyy-MM-dd hh:mm:ss')
	start_date_timestamp = system.date.toMillis(start_date)
	end_date_timestamp = system.date.toMillis(end_date)
	var_list = ["InputVA", "InputVB", "InputVC", "CurrentA", "CurrentB", "CurrentC", "ActPowerA", "ActPowerB", "ActPowerC", "ActPower3P", "ActPowerkWh3P_cal"]
	for pd_index, pd_dict in pd_data.items():
		pd_name = pd_dict["pd_name"]
		val_list = []
		## ํžˆ์Šคํ† ๋ฆฌ์•ˆ ๋ฐ์ดํ„ฐ db๋Š” ์›”๋งˆ๋‹ค ๋ฐ”๋€Œ๋ฏ€๋กœ ์‚ฌ์šฉ๋˜๋Š” db ์„ ํƒ
		tblnamequery = (
			"SELECT TOP 1 [pname] "
			"FROM [sqlth_partitions] "
			"WHERE drvid = 1 "
			"ORDER BY start_time DESC "
		tblname = system.db.runScalarPrepQuery(tblnamequery)
		#print(tblname)
		for var in var_list:
			# ์—ฌ๊ธฐ์—์„œ feeder_no ๋ณ„๋กœ ํŠน์ • variable์˜ tag history ๋ถˆ๋Ÿฌ์˜ค๊ธฐ
			tag_path = (pd_name + "/Feeder1/" + var).lower()
			#query3 = """SELECT "id" FROM sqlth_te WHERE "tagpath"=?"""
			#print(tag_path)
			query3 = (
				"SELECT TOP 1 [id] "
				"FROM [sqlth_te] "
				"WHERE [tagpath] = ?"
			tag_id = system.db.runScalarPrepQuery(query3, [tag_path])
			lastVal = 0.0
			fisrtVal = 0.0
			val = 0.0
			subval = 0
			#print(unicode(tag_id))
			if tag_id:
			#data3 = system.db.runPrepQuery(query3, [tag_path])
			#if not data3: continue
			#tag_id = data3.getValueAt(0, 0)
				if var <> "ActPowerkWh3P_cal":
					query4 = (
						"SELECT AVG(floatvalue) AS avgVal "
						"FROM " + unicode(tblname) + " "
						"WHERE tagid = " + unicode(tag_id) + " "
						"AND t_stamp BETWEEN " + unicode(start_date_timestamp) + " AND " + unicode(end_date_timestamp)
					subval = system.db.runScalarPrepQuery(query4)
					if subval:
						val = subval
				else:
					queryL = (
						"SELECT TOP 1 floatvalue AS lasVal "
						"AND t_stamp BETWEEN " + unicode(start_date_timestamp) + " AND " + unicode(end_date_timestamp) + " "
						"ORDER BY t_stamp DESC"
					lastVal = system.db.runScalarPrepQuery(queryL)
					queryF = (
						"ORDER BY t_stamp ASC"
					fisrtVal = system.db.runScalarPrepQuery(queryF)
					if (lastVal - fisrtVal) > 0:
						val = lastVal - fisrtVal
					else:
						val = 0.0
			val_list.append(val)
			#query4 = """SELECT "floatvalue" FROM sqlt_data_1_2023_12 WHERE "tagid" = ? AND "t_stamp" BETWEEN ? AND ?"""
			#data4 = system.db.runPrepQuery(query4, [tblname, tag_id, start_date_timestamp, end_date_timestamp])
			#data_list = [data4.getValueAt(i, j) for j in range(data4.getColumnCount()) for i in range(data4.getRowCount())]
			# '์œ ํšจ์ „๋ ฅ๋Ÿ‰ - ๋ˆ„์ '์ผ ๊ฒฝ์šฐ
			#if len(data_list) == 0:
			#	val_list.append(0)
			#elif var == "ActPowerkWhC":
			#	val_list.append(data_list[len(data_list) - 1] - data_list[0])
			#else:
			#	val_list.append(sum(data_list) / len(data_list))
		print(val_list)
		# val_list์˜ ์›์†Œ๋ฅผ ํ•˜๋‚˜ํ•˜๋‚˜ ๊ฐ€์ ธ์™€์„œ pd_data์— ์ €์žฅ.
		if len(val_list) > 0:
			pd_data[pd_index]["vol_r"] = val_list[0]
			pd_data[pd_index]["vol_s"] = val_list[1]
			pd_data[pd_index]["vol_t"] = val_list[2]
			pd_data[pd_index]["cur_r"] = val_list[3]
			pd_data[pd_index]["cur_s"] = val_list[4]
			pd_data[pd_index]["cur_t"] = val_list[5]
			pd_data[pd_index]["power_r"] = val_list[6] / 1000
			pd_data[pd_index]["power_s"] = val_list[7] / 1000
			pd_data[pd_index]["power_t"] = val_list[8] / 1000
			pd_data[pd_index]["power_sum"] = val_list[9] / 1000
			pd_data[pd_index]["ActPowerkWh3P_cal"] = val_list[10]
	# result
	headers = ["floor", "location", "pd_name", "use_rate", "vol_r", "vol_s", "vol_t", "cur_r", "cur_s", "cur_t", "power_r",
	           "power_s", "power_t", "power_sum", "powerkWh_c"]
	result = []
	for pd_index, items in pd_data.items():
	    floor = items["floor"]
	    location = items["location"]
	    pd_name = items["pd_name"]
	    use_rate = items["use_rate"]
	    vol_r = items["vol_r"]
	    vol_s = items["vol_s"]
	    vol_t = items["vol_t"]
	    cur_r = items["cur_r"]
	    cur_s = items["cur_s"]
	    cur_t = items["cur_t"]
	    power_r = items["power_r"]
	    power_s = items["power_s"]
	    power_t = items["power_t"]
	    power_sum = items["power_sum"]
	    powerkWh3P = items["ActPowerkWh3P_cal"]
	    # ๋ฆฌ์ŠคํŠธ์— ์ •์ˆ˜๋กœ ๋ณ€ํ™˜๋œ ๊ฐ’์„ ์ถ”๊ฐ€
	    result.append([floor, location, pd_name, use_rate, vol_r, vol_s, vol_t, cur_r, cur_s, cur_t, power_r, power_s, power_t, power_sum, powerkWh3P])
	# ํŠœํ”Œ๋กœ ์ •๋ ฌ
	result = sorted(result, key=lambda x: x[0:2])
	# ๋ฆฌ์ŠคํŠธ๋ฅผ ๋ฐ์ดํ„ฐ์…‹์œผ๋กœ ๋ณ€ํ™˜
	dataset = system.dataset.toDataSet(headers, result)
	data["result"] = dataset
When you finally do "data["result"] = dataset ", the following error occurs.
error
File "", line 195, in
TypeError: com.inductiveautomation.ignition.common.script.builtin.DatasetUtilities$PyDataSet indices must be integers
You are re-using the supplied data variable as your own local variable name (in the first runQuery()), destroying it. So it isn't a map of data keys after that.
Use more descriptive variable names.
Thank you so much
