Report Simple table border stroke line colors are not saved
In report simple table settings, I am not able to change the color of table border ( stroke color) . When I change the color of stroke in designer and go to preview mode those settings on the stroke color are lost. This behavior is only related to default borders of the table that comes when table style is selected. I am using classic2 style.
Ignition version 8.0.17
Is there anything in the designer log about this? I found a ticket for a different issue with borders on the simple table and testing shows this was working about the time 8.0.17 was released, so I suspect something else might be going on.
In Gateway log I don't see anything pertaining to this activity.
Designer log is this different than GW log?
Yes, different. Go to the Help menu and pick Diagnostics.
Oh I get it .
I don't see any error. I just see the update and save being logged. No error reported in log.
In the "Report Error" Button pop up does not show information on stack trace.
Here is the full information on this button.
java.lang.Throwable: No Stack Trace
	at com.inductiveautomation.ignition.client.util.gui.diagnostics.EventDisplayPanel.actionPerformed(EventDisplayPanel.java:187)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
	at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:96)
Ignition v8.0.17 (b2020111211)
Java: Azul Systems, Inc. 11.0.7
That's very odd. Consider contacting support, but don't be surprised if you are told to upgrade. (v8.0 is long past end-of-life.) BTW, there's a soon-to-expire special offer for companies that have no support to buy it now without the upgrade penalty. You should tell your bosses.
