Report simple table text color or fill not working
I cannot seem to get the reports keychains to work properly.
I have a simple table with multiple columns using the header , data, and summary
I want to change each data cells color either fill or text based on its value.
I have in column 3 a data key.
The value populates fine
I then have dynamic key in the text color that is
Data_key>50?"red":"black"
Where data key is the value
The text does not change colors and the values in the column are all greater then 50
Please help
I have looked and read the keychain expressions guide.
Hi Brian,
If you copy and paste from the text you posted the above:
But replace only the portion right of the ?, it should work.
I see i was missing the quote at black. Duh..thanks
