Report Simple Table
Hi guys,
I have a problem with the simple table component in the report module. When I add data to it from dataset (imported from tags), only the first data (first row) will display, i can’t make it dynamic.
When I test with the data in the tutorial :
equipment,downtime
conveyor line,78
filler, 68
labeler,84
palletizer,27
It works, but If I just replace one letter from the header column for example, the data will stop to be displayed dynamically. There is something I don’t understand for sure but I can’t what.
Thank you guys !
Be sure your dataset’s column names are valid for reports. And avoid the bug described here:
Thank you for your answer.
Since I copied the data from the tutorial, I think the format is good and I’m just changing one letter and it doesnt work anymore, plus there is no number in the column names/
where are you changing this one letter?
Wherever I change it, doesnt matter. See on this example :
iage3
This is the original data. Then in the preview :
Here if I remove the “i” from equipment, here is what I get :
Of course, I remove the “i” from the static csv data, but also from the designer (@Equpment@)
But only the first column displays
I tried with a bunch of other data, none has numbers at all in column names, still nothing.
Should probably call support and have them take a peek. From what I can tell everything seems to be configured correctly.
Thank you, will do that then.
