Report SQL data source resulting in "Invalid column name'{....}'"
I'm doing a project requiring a series of reports - and I haven't done any reports for a while. I've reviewed all the relevant IU videos on the reporting module as a refresher. Here's the current problem:
Figure 1. SQL data source.
Figure 2. The BatchId parameter.
Error message in Preview tab:
WARN: An error occurred while executing Query SELECT	*
FROM	HEADER
WHERE	BATCHID = "{BatchId}"	-- e.g. '001234567'
-- Invalid column name '{BatchId}'.
Can anyone suggest why it thinks '{BatchId}' is a column name?
Thanks!
The SQL standard uses double quotes as column and identifer delimiter. I don't believe you need the double quotes around the {BatchID} as it should take the paramter type into account. Much like parameters for Named Queries.
It might also be unhappy with the comments in the query string. I know there have been issues with that in other areas.
Use a ? for the parameter placeholder in the query editor, then a parameter input box will popup where you put {BatchId}
Thanks for the reply.
The SQL standard uses double quotes as column and identifeir delimiter.
Oops! Yes. I was experimenting on the basis of a wider web search.
That was my thinking too, but it's contradicted by the docs at Basic SQL Query | Ignition User Manual. (See the bit on Report Parameters in a Basic SQL Query.)
I'm continuing to investigate!
Doh! I found it.
Don't enter the {paramameter} into the query. Use the ? and an expression dialog will open below.
Thanks!
Did you not see my reply?
No, I missed it in my excitement!
I'll mark yours as the solution. Thanks!
