Report Table dynamic postiton Y
I have a report with multiple tables. Sometimes one of the tables contains more rows than expected, causing it to grow in height and overlap with the table below it.
I was wondering if it's possible to dynamically position a table based on the rendered height of the previous table. Ideally, I'd like to set the current table's Y position to:
Previous Table Height + 5
so that it always starts 5 pixels below the end of the previous table.
I noticed that the Y property can be bound to a parameter, but I couldn't find any way to reference the previous table's rendered height. Is this possible in the Ignition Report Designer, or is there another recommended approach to prevent tables from overlapping?
Use table groups to "flow" variable sized elements.
