Report unexepctedly moving components?
Using 8.1.48
I have a report that has a giant header and then is one table group of 3 tables. The entire table group componentis 505 pixels tall.
The first table in the table group is just the header (no details/summary) and I use this to make the top header of the actual page. This is 130 pixels tall.
The second data in the table group is an actual table, in this use case it is always 8 rows (header + 7 rows) all 18 pixels tall for a total of 144 pixels.
The last table group is for me to do a custom bottom part of the page after the table and that is 200 pixels.
All together these 3 tables combine for 474 pixels.
the first two tables in the tablegroups flow fine, I have my custom header of the page, followed immediately by the data table and then the third table group starts right after it - but towards the bottom some components get pushed up and I can’t figure out why, initially I thought it was I was trying to cram too much into the height but after doing the above calculation it seems like I have a little cushion still.
This is what I see in my designer -
and what I see on preview/when I actually make the report
That text under Quality reviewer is from the @Disclaimer@ which should be appearing underneath the simple table.
I’ve tried resizing to my wits end. I don’t know if im missing some setting that would help with this. I’ll be calling tech support tomorrow for assistance but posting for posterity/in case anyone’s figured this sort of thing out.
Even though the designer shows thin rows, the final output shows normal sized rows with padding around the text which makes the entire table larger than you think and appearing over the disclaimer. You may want to remove any cell padding to ensure the height of the rows doesn’t change.
