Currently I am trying to set up a report that has a bar graph in it. I have set this bar graph up so that there is a “New series for each: Dataset Object” instead of for every “Key”. I did this because I want to have a bar for each column in my table and I want the x-axis to be a date. Everything on the graph looks good except for the color legend. For some reason I can’t get the legend to do the automatic listing when the new series is set for each dataset object. It will list all of the colors, but it will not repeat what is typed in the legend text. Below are a couple pictures of what I mean.
This is an example of the legend repeating with a new series for each key:
This is an example of the legend not repeating labels with a new series for each Dataset Object:
I have been able to work around this by adding in text labels, but the problem is I can’t get the color rectangles in the legend to space apart for when the legend text takes up 2 rows. Is there some setting that I am missing with this?
Thanks,
-Will
