I am having an issue or the report viewer where when I save to .xls and try to open the file it says it is corrupt and won’t open.
Saving as a pdf works fine.
Here is an example of the error.
So when you hit Yes to open it anyways, what does it do?
Opens a blank excel document named report
What version of Ignition are you on? There’s a bug in 7.9.8 with excel exports not working - not a bug in prior versions, and fixed in 7.9.9+.
with 7.9.13 I have the same problem…
there are some driver to install in server that may be is forgetted?
No.
In all versions of Ignition prior to 8.0.6 (pretty sure) any export to Excel functionality is actually creating an Excel-compatible XML file and setting the file extension to .xls. Excel knows how to parse this (hence you’re able to open it) but complains about the mismatch between the document format and filetype.
In the latest versions, Excel exporting has been revamped and exports “real” .xlsx documents. It’s not possible to backport this to 7.9, because the required library (Apache POI) at the required version doesn’t support Java 6, a requirement for 7.9’s LTS nature.
This may be related to an issue my customer is having. They are currently on 8.0.7. Customer saves a report to an xlsx file and when double clicking to open in excel, receives an error that the filetype is invalid. This happened on their primary SCADA server as well as someone logged in remotely through a VPN on their personal laptop. On the SCADA server, I tried several things with varying luck.
For reference, SCADA server has Excel 2016, customer's personal laptop and my work laptop both running Excel from Microsoft 365.
You should test on something newer. (Note that the 8.0.x is end-of-life--has been for a couple years. If this is a bug, it won't be fixed.)
