I have a transaction group that runs on a schedule and logs the values every 15 minutes for Energy Delivered kWh and Energy Delivered kVAr. I have the values displaying on a a report with a Date and Timestamp, but I am needing to add another column that will run the below calculation. What would be the best way for me to go about doing this?
For the real power integrated demand, every time we query the kWh delivered, we would then calculate the demand by subtracting the reading from 15 minutes earlier and then multiplying the result by 4 (there are four, 15 minute intervals per hour). The same procedure applies to the kVAr delivered. As an example –
At 13:45 the delivered kWh reading is 2846.88 and the delivered kVArh reading is 722.66
At 14:00 the delivered kWh reading is 2882.19 and the delivered kVArh reading is 735.22
The calculation would be as follows for kW demand:
[The kWh reading at 14:00 minus the kWh reading at 13:45] * 4 or (2882.19 – 2846.88)*4 = (35.31)*4 = 141.24 kW demand for the period ending at 14:00.
Similarly, the calculation for kVAr demand would be:
[The kVArh reading at 14:00 minus the kVArh reading at 13:45] * 4 or (735.22 – 722.66)*4 = (12.56)*4 = 50.24 kVAr demand for the period ending at 14:00.
Any help would be greatly appreciated. Thanks.
