Reporting change font to bold if value is null
is this possible in reporting? change the row table font size or font using key expression ?
use something like this to pickup if the value is NULL and change the font size or some other attribute.
t_stamp?"Dialog, Plain, 7":"Dialog, Plain, 12"
I tried this on a table row but its not working, maybe its not possible on font? I'm not sure Thanks for the reply tho!
make sure you are NOT using the @ prefix, suffix as in the OP.
Nvm, this one worked! thank you so much, I tried to preview it again and saw the changes
cool :slight_smile:
