Hello all. I am using 7.9.5
None of my automated reports are going out. I have over a 100 reports “executing” The oldest report is about 20 days old.
These were working in the past.I was setting up a new report and it was not being delivered. T
When I send a test email from the gateway those emails are going through.
I have tried the run scrip as the reporting action and get the same error
system.report.executeAndDistribute(path=“daily/Linewalk”, project=“Quality_Tools”, action= “email”,
actionSettings = {“to”:[“myemail@mycompany.com”], “smtpServerName”:“mycompanySMTP” , “from”:"reporting@myplant.com", “subject”:“Production Report”})
actionSettings = {“to”:[“myemail@mycompany.com”], “smtpServerName”:“mail.mycompany.com” , “from”:"reporting@myplant.com", “subject”:“Production Report”})
GatewayException: com.inductiveautomation.ignition.gateway.smtp.SmtpManager.sendEmail(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;IILjava/lang/String;)V
caused by NoSuchMethodError: com.inductiveautomation.ignition.gateway.smtp.SmtpManager.sendEmail(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;IILjava/lang/String;)V
Ignition v7.9.5 (b2017111615)
Java: Oracle Corporation 1.8.0_151
if I try to manually send the report in the report designer I get this error message.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.gateway.smtp.SmtpManager.sendEmail(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;IILjava/lang/String;)V
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:315)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:856)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:52)
at com.sun.proxy.$Proxy26.execute(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.schedule.SchedulePanel$ActionsPanel$ExecuteNowWorker.doInBackground(SchedulePanel.java:674)
at com.inductiveautomation.reporting.designer.workspace.schedule.SchedulePanel$ActionsPanel$ExecuteNowWorker.doInBackground(SchedulePanel.java:647)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NoSuchMethodError: com.inductiveautomation.ignition.gateway.smtp.SmtpManager.sendEmail(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;IILjava/lang/String;)V
at com.inductiveautomation.reporting.gateway.actions.EmailAction.perform(EmailAction.java:131)
at com.inductiveautomation.reporting.gateway.scheduler.ReportSchedulerTask.reportAction(ReportSchedulerTask.java:320)
at com.inductiveautomation.reporting.gateway.scheduler.ReportSchedulerTask.runImmediate(ReportSchedulerTask.java:292)
at com.inductiveautomation.reporting.gateway.scheduler.ReportSchedulerTask.runImmediate(ReportSchedulerTask.java:260)
at com.inductiveautomation.reporting.gateway.ReportingGatewayHook$RPC.execute(ReportingGatewayHook.java:532)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:172)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:405)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:518)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
at java.lang.Thread.run(null)
Java: Oracle Corporation 1.8.0_1com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.gateway.smtp.SmtpManager.sendEmail(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;Ljava/util/List;IILjava/lang/String;)V
