Reporting in Perspective ( Get Current User )
Hi guys, have a good days.
Currently, I’m doing the reporting in perspective which I will show the report in report viewer. In this case, I actually want to put the current user in the report module which I will get the current user that login in the session and put in the reports. May I know it is possible.
The best way I think of doing this is create a new parameters and get the current user in the parameters but when I do this it dint work. May I know anyone do this before.
Thanks in advance.
This is probably the correct answer. Please show us what you tried.
Be sure to use Perspective’s authenticated user “session.auth.user.userName” instead of Vision’s “system.security.getUsername”.
What I had tried was I just write the code of userName = session.props.auth.user.userName
That looks correct, but I suspect no user is logged in. Does your project require authentication? If not, you might want to look into at least requiring a user log in before accessing the View which contains the Report.
Hi @cmallonee, Image attached is the code that I write and the error message that prompt up. May I know what solution I should do to solve these problems.
2.
Thanks in advance.
Ah, the Report itself has no concept of a session. You will be unable to supply a default value which is a username. Perspective should supply the username as a param of the property. I have verified this does indeed work.
The report should be set up just like you have it, but supply a placeholder string in the expression. In my example I supply a value of “Fake”. My username variable is just userName, but the name does not matter. Your Perspective Report component should supply a case-specific param, and you should bind that param to the session property we mentioned previously.
Report Configuration:
Screen Shot 2021-08-11 at 7.16.30 AM
Perspective component configuration (you can see in the background that the report is using “admin” as the username because the admin user is logged into the Designer):
