I cannot size the Labels control by dragging its corners to the desired width/height. What do you suggest? Try-and-error by inputting the width and height in the respective input boxes? Rather annoying indeed.
Thank you,
regards
Thank you,
regards
Label sizes are controlled by the Label Formatting setting. These have all the common Avery sizes, in numerical order. It should be easy to find a cross-over if you’re using another brand of label.
Ok, I saw it. In my opinion it would be nice, if it were possible to stretch the component using its graphic handles too.
Be sure to post this at ideas.inductiveautomation.com – that’s where we’ll pull new features from.
