I have just upgrade one of our systems to 7.8 and started in on the new reporting. When i try to open screen with new report viewer on it i get the following error. I have tried this on client running 1.8.60,1.8.21,1.6.15 and they all do the same thing. Server is running 1.8.6. Have tried this with blank report and with converted report both with same result.
ERROR [WindowCache-AWT-EventQueue-2] Unable to open window “Report/Alarm/Chronology Test”.
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error deserializing element “<c”
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.createException(XMLDeserializer.java:929)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementStart(XMLDeserializer.java:810)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:151)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:316)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:236)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:275)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:214)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:434)
at com.inductiveautomation.factorypmi.application.FPMIApp$RuntimeWindowOpener.openWindow(FPMIApp.java:1718)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:1018)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:1010)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$1.run(NavUtilities.java:205)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:707)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapWindow(NavUtilities.java:203)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapTo(NavUtilities.java:112)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapTo(NavUtilities.java:93)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.call(ScriptManager.java:428)
at org.python.core.PyObject.call(PyObject.java:387)
at org.python.core.PyObject.call(PyObject.java:391)
at org.python.pycode._pyx16.f$0(event:propertyChange:6)
at org.python.pycode._pyx16.call_function(event:propertyChange)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:624)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.access$000(ActionAdapter.java:40)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter$ActionRunner.run(ActionAdapter.java:280)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Caused by: java.lang.NullPointerException
at javax.swing.ImageIcon.(Unknown Source)
at com.inductiveautomation.reporting.ErrorableContentPanel$SlidingContentPanel.(ErrorableContentPanel.java:176)
at com.inductiveautomation.reporting.ErrorableContentPanel.(ErrorableContentPanel.java:44)
at com.inductiveautomation.reporting.components.ReportViewer.init(ReportViewer.java:333)
at com.inductiveautomation.reporting.components.ReportViewer.(ReportViewer.java:148)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.startSubElement(ComponentDeserializationHandler.java:72)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementStart(XMLDeserializer.java:807)
… 58 more
