Reporting Module - Error getting sample data
I just recently started using the Reporting Module and ran into a problem inside the Designer when trying to pull in data. I am using a named query that is as follows: Select * From partdata. When I select the Designer tab the Error getting Sample Data occurs. Below is the details table from said error.
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: 'com.inductiveautomation.ignition.gateway.expressions.TagReferenceBinder com.inductiveautomation.ignition.gateway.expressions.TagReferenceBinder.newReadBinder(com.inductiveautomation.ignition.common.expressions.FunctionFactory, java.util.function.Supplier)'
at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
at java.desktop/javax.swing.SwingWorker.get(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.done(SampleData.java:145)
at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:99)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: 'com.inductiveautomation.ignition.gateway.expressions.TagReferenceBinder com.inductiveautomation.ignition.gateway.expressions.TagReferenceBinder.newReadBinder(com.inductiveautomation.ignition.common.expressions.FunctionFactory, java.util.function.Supplier)'
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:908)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:53)
at com.sun.proxy.$Proxy51.getReportData(Unknown Source)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:135)
at com.inductiveautomation.reporting.designer.workspace.design.SampleData$SampleDataLoader.doInBackground(SampleData.java:112)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.NoSuchMethodError: 'com.inductiveautomation.ignition.gateway.expressions.TagReferenceBinder com.inductiveautomation.ignition.gateway.expressions.TagReferenceBinder.newReadBinder(com.inductiveautomation.ignition.common.expressions.FunctionFactory, java.util.function.Supplier)'
at com.inductiveautomation.reporting.gateway.ReportDataExpressionParseContext.createTagBinder(ReportDataExpressionParseContext.java:32)
at com.inductiveautomation.reporting.gateway.ReportDataExpressionParseContext.(ReportDataExpressionParseContext.java:22)
at com.inductiveautomation.reporting.gateway.api.ReportExecutionContext.(ReportExecutionContext.java:85)
at com.inductiveautomation.reporting.gateway.api.ReportExecutionContext$ReportExecutionContextBuilder.build(ReportExecutionContext.java:390)
at com.inductiveautomation.reporting.gateway.ReportStatusManager.getReportExecutionContext(ReportStatusManager.java:81)
at com.inductiveautomation.reporting.gateway.ReportingGatewayHook$RPC.getReportData(ReportingGatewayHook.java:572)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(null)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:167)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:431)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1450)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1631)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
at java.lang.Thread.run(null)
Ignition v8.1.18 (b2022061518)
Java: Azul Systems, Inc. 11.0.15
Any suggestions are much appreciated. I do have a support ticket in but no luck so far. Given I just started using Ignition I'm hoping its a silly mistake on my end.
Your reporting module version and your gateway version don't agree (this should have been prevented, which is an error on our part), but I think the reporting module you have is newer than your Ignition platform. You should update to the latest version for both at your earliest convenience.
Installed the correct version of the Reporting module which resolved the issue. Thank you!
