Ignition Platform 8.1.24
Reporting Module 6.1.24 (licensed)
I have a report that I need to output as a native XLS, which to everything I am seeing is working (IE xls file extension, Excel doesn’t flag it as a filetype mismatch). The issue I have is I can’t get rid of the borders around my data in a Table. No amount of adjusting TextShape stroke settings is actually making a difference. Excel opens the worksheet with grid lines turned off, and borders on only the cells that have data. Is there a way to get rid of the borders or would this be Excel doing this when opening? I need XLS (and not CSV or XLSX) so the data can be imported into an older (and worse) system and while I don’t think the borders will be a problem for another team taking care of the import I’d like to remove them to just jump past that possible next hurdle. Thank you.
