Just trying to export from scada data daily for another platform.
(coding up another static table Report)
Just need to convert a few tank level from
feet
to
inches
(the perspective view does this by design for the web user, but I don't see a reporting option - other that python code - and a history query w python code takes a while over a basic tag history data source)
Checked the Docs
Checked the forum
Any and all options are appreciated.........
Modify the query.
SELECT
Timestamp,
Level * 12 AS LevelInches
FROM ...
Where in the normal report builder - tag history data source - can I modify the SQL?
Don't see that.
I assume you mean for a report - data source - sql query (which means parsing the history sql tables)
There it is
Reporting
Tag historian query
after the data source alias is defined
in the Design Tab
inside the @_@
@tag_history.bulldog compressor station tank 1 oil * 12@
No, you can't modify the SQL for a historian query. You will need to reprocess that result with a script datasource.
Or, if reporting in tabular form, just use a formula in the cell that normally would report the feet.
{ You will probably want to omit the tag_history. prefix from the column reference in the cell. }
There's a demonstration about 35 s in on the IU video.
Yep (you found it)
That is what I was looking for.
(wish there was a quick mention in the Docs - yes you can do data source key calc - go look here.......)
