I noticed that when using Tag Historian Query data source if at tag that did not have a value change within the start and end binding it will contain the value stored out side of the date range.
When using a script data source and below tag to query the tag value I get a null value if there is no data stored within the time range.
system.tag.queryTagHistory(paths=tagPath, startDate=data[‘StartDate’], endDate=data[‘EndDate’], retrunSize= 1000 ,aggregationMode=“MinMax”, columnNames=dataKeyAlias,returnFormat=‘Wide’)
Is there a way to use the script data source but get the same output as the Tag Historian Data source?
