Reports from SQL server
Is there an Ignition Module to handle/design reports (or web reports) as the one in the next image?
-in the top I want to have the way to add filters that the user can select
-in the bottom get the data from the report in tabulated way
-All the data comes from SQL server tables and stored procedures that returns data
-This data is stored in SQL from Ignition and other sources.
The one of the image works in WEB but I don't have issues if it works inside of the Ignition platform.
thanks
Using the reporting module plus either the Vision or Perspective module you can do this. Tie the user selected filters to report parameters.
Excelent , thank you
