Hello, I have reports that use a sliding date range. Every time I open up the window, the report shows “generating Report” at the bottom, for ever, and I cant do a thing after that. Has anyone ever had this issue? I can give more details if you need it.
why does date range sometime revert to a date of 1970, anyone have this issue???
the report uses an SQL query, polling mode is relative
thanks
