Required password for user/role
Trying to set up some users on a vision project but the new user option requires a password. Is there a work around? running ver 8.1.37
Where has a password previously not been required? It's not obvious where you are trying to do this at. Could you show us?
Hey, A password is required for each user. There isn't a workaround for this requirement. You'll need to provide a password for each new user during setup.
There is an auto login option:
https://docs.inductiveautomation.com/docs/8.1/ignition-modules/vision/vision-project-properties/setting-up-auto-login#client-auto-login
This is a fairly common practice that allows basic users to gain access to a Vision client session without having to bother with a password using a generic account. Usually, the splash page will also include some way to switch users to a password protected account for clients that require a higher privilege level than the auto login account provides. The auto login account should be a read only privilege level.
