hello
Is there a way to get the instances back to the same udt configuration?
thanks you
hello
thanks you
What do you mean ? Do you want your UDT instances to reset back to the default values from the UDT configuration ?
If so, when do you want it to happen ?
Yes,I wanted to know if it is possible for the instances to return to the same configuration as the udt, without having to click the green button in each instance.
I want it to happen when a button is clicked for example.
