Does anyone know what the process is for resetting the Node Info tags for a particular Sparkplug Edge Node using MQTT Engine? The documentation indicates there is a writable tag called “Node Info/Reset Info” for this (reference: ME: Tags - MQTT Modules for Ignition 8.x - Confluence) but I’ve been unable to make it work by having the node publish a NDATA message with a “Node Info/Reset Info” metric. Maybe I’m missing something. Any ideas?
Thanks!
