Reset Value
We have created a group in factory sql and table in mysql for the corrosponding group. In factory pmi i have textbox,
for the textbox i have written a sql query to calculate the sum of column and display the value in the text box. I need to reset the textbox value based on the date and time for every day (at 12.00 pm).
Thanks,
Vinay
If you are using MySQL, change your query to read
SELECT IFNULL(SUM(some_column),0) FROM some_table where date(t_stamp) = date(now())
I dont know the corresponding query in MSSQL though.
How do i reset the value using factory pmi and not using sql.
I believe that the answer above was referring to a query you’d use in a FactoryPMI query binding to calculate the display value for the text box.
