Resetting Gateway password on Mac
Hi all, I am new user trying to go through the basics, I was setting up ignition, and typed in my gateway password (as it asks) and i used my normal password I use for a lot of things, and my browser even saved it. I went to log in and no dice, so I have tried to use the GWCMD tool to no avail. I understand there are a lot of users on windows, and I tried the executable shell file and no luck there either. I can pull up the directory, and I can pull up all the available commands, and password and -p is not there as an available command. I also used sudo (superuser) to execute the command and there was no difference. I am wondering If I am missing some small portion in my command. Thanks
You should be looking for gwcmd.sh, not ignition.sh (I think)
that worked! Thank you good sir.
This worked to get the command to come up but when i type in the -p it says command not found.
What version are you on? Can you copy/paste the exact command you executed and its output?
/usr/local/Ignition/gwcmd.sh
The version is the maker edition 8.1.39 Mac version is catalina
That makes me think you aren't putting a space before that dash. Should be:
./gwcmd.sh -p
That worked thank you. I'm new to Ignition on Apple.
I completed the steps successfully in terminal, and was able to set a new username and password. However, when i login with the new credentials i am getting this error on the home screen.
Did you restart the gateway service as directed? It will force you to go through partial commissioning to set a temporary new user and password.
Yes, i did through terminal. Then i created a new user and signed in with it. However im still getting the same result.
You should have support look over your shoulder. There's some nuance that we cannot see.
