Hi, I´m new in factory PMI, I want to resize a circle shape, we need to simulate the diameter of a roll to be consumed, I can´t find the size property for Jhyton or something like this, Thanks
The size and position doesn’t show up as properties in FactoryPMI. You have to use the:fpmi.gui.resizeComponent
fpmi.gui.moveComponentfunctions. Typically, people add dynamic properties to the component and a propertyChange script that calls those functions:if event.propertyName == "dynamicPropName":
fpmi.gui.resizeComponent(event.source, 100, 200)
Are you using Ignition or FactoryPMI?
Thank you Travis, I will try with your solution, great support.
Nathan, I´m using Factory PMI
Thank you all.
